Ebony: 91 black 1jzgte (proefi friendly)
stevenr816
932
Phoenix,AZ
flyjum;1912540 said:
What transmission mount/engines mounts were you using?
Solid motor, poly tranny.
Hands down there absolutely no point in keeping a r154 at that power level. I haven't found anyone yet that hasn't broken any at 600+ wheel.
How would street driving suck ass? Freeway, eh but you can get 3.5X rear gears if your that concerned.
Does it suck power, technically. But the car is going to be so much faster that it doesn't matter. Endless pull in your power band, no lag between gears etc.
Albert
May 13, 2009
1,710
Tempe, AZ
Going with a th350, adapter plate for a340 bellhousing, custom ATI 9'' coverter, transbrake, quicksilver shifter.
Ill get proefi temp sensor, cooler, lines etc etc too. hopefully I wont have issues again.
May go with a 3.58 rear end
flyjum
75
Mesa AZ
What sort of RPM on the stall does he plan on running?
I would think a 4,500~ rpm stall is needed unless he is running spray to get the boost up on the brake.
No OD with 3.5X gears in a street car with a 4k+ rpm stall will cause some pretty bad heating issues
If his engine RPM is below the stall RPM on the freeway he will just be slipping converter
He could swap in NA gears in the rear to pull the RPM higher
Do they make lock up converters for this application?
stevenr816
932
Phoenix,AZ
IndigoMKII;1912666 said:
Sounds like someone is chasing 10's. Do you already have a drivetrain collar and ATI damper etc etc?
9s easily auto. Easy 10s with the 5sp setup now.
Sparky33;1912686 said:
who sells the th350 to a340 adapter?
A vendor online, it's not a bolt on occasion. You have to cut the bellhousing off the GM trans and machine it flat. Then the adapter bolts to the front of the pump.
4500 rpm stall is what I would choose as well, cause it won't hit 4500 until under heavy load. Spray would be good if he's going to drag, just to get it up on stall faster.
Tyler hasn't had one bit of Trans temp problems whatsoever. Not even remotely close to getting hot. It usually sits around 140-150 cruising and 180 at the track after a couple passes. With a cooler and a fan. Fans on key power too.
No lock up converters on 350/400/PG.
stevenr816
932
Phoenix,AZ
suprakidd;1912886 said:
id pay for a ride-a-long in that bitch, those friends of yours... super jelly LOL.
looks like way to much fun man :p
It wasn't anything special, was a pretty slow time machine IMO LOL
Albert
May 13, 2009
1,710
Tempe, AZ
So have an update.
I'm gonna be giving the built r154 one more go at this thing and see how long it lasts before I tear gears apart...
Albert
May 13, 2009
1,710
Tempe, AZ
naaaaaaaaaa
Do you know who I am?! ;)
ill be CMM the 2nd, 3rd gear and counter shaft. get it cad modeled by Dustin, and Ill machine it out of 9130 alloy.
but for now ill thorw all the bearings in and all the MC parts and see how it hangs
IndigoMKII
2,181
Madison, Virginia
Albert;1914698 said:
naaaaaaaaaa
Can I get those CAD drawings when you're done?
Albert
May 13, 2009
1,710
Tempe, AZ
Yeah I think I have you beat, mine was pure metallic but also burnt
From the forks going out at the same time
