Hello everyone. I've been racking my brain for a while now. Car has been running fine until one day it just won't start. I have found a work around but the shop that inspect my car told me to fix the issue because the car is starting without pushing in the clutch. I have spent countless hours doing research and tried different thing before posting this question. I currently removed the starter relay and jumped the terminal. (Please see pic below) That's the only way it would start.
What I've done:
1. Replaced starter relay.
2. Replaced clutch switch.
3. Did a starter relay mod. (Not sure if that helped)
4. Battery on tender so it's fully charged.
5. Reset factory alarm following instructions from one of the thread on this forum.
6. Disconnected the fuse for aftermarket alarm.
I bought this car in 2002 and it came with an aftermarket alarm. Factory alarm also functioning because it went off on me several times when I disarmed the after market alarm system. Never had any problem until now. Right now I'm trying to disconnect the factory alarm. I have follow TSRM diagram for location of the factory unit. I found cruise control computer, cruise control main relay but I don't see the factory alarm computer. Is the factory alarm not located beside the cruise control unit? By the way, I place my finger on the starter relay while turning the key and pressing in the clutch, the relay does not click at all. I pulled the starter relay out and applied voltage to test and both of the relays, new and old unit, click when I applied 12V to two terminals.
Any one with similar issue or any idea of what is wrong, please chime in. I appreciate any input. Thank you.
Starter relay jumped. The car starts fine with these connections but it won't pass Virginia state inspection.
Under dash beside Cruise control. Don't see factory alarm.
What I've done:
