can NA fuel pump slow turbo engine down?
van1684
chicago
i did a na-t swap and it's running a little slow. i was wondering if my na fuel pump doesn't have enough fuel for my engine.
xXxICExXx
366
Abbotsford, BC, Canada
considering to run a vehicle you have to get the correct ratio of air/fuel, for a turbo you need a lot more fuel flow to match the increase in air flow. I'm not sure if the NA uses a different pump than the turbo though.
shaeff
Kurt is FTMFW x2!!!!
9
Around
on a stock turbo motor you won't notice. on a built turbo motor you'll have melted pistons, and you'll definately notice!
moral? get a new pump!
-shaeff
lagged
1991 1JZ
new rochelle
the pumps are the same.
replace it anyway. our fuel pumps are up to 20 years old now. walbro fuel pumps are cheap.
