setup :
2jzge
tt head gasket
t4 exhaust manifold signle turbo.
stock fuel rail with denso 550cc injector.
aeromotive fuel pressure regulator with vacuum plugged
i run the 7mgte electronic.
7m coilpack.
7m trottlebody
7m cam position sensor.
7m Knock sensor.
deleted maf. i run hks vpc with boost pressure sensor. and iat sensor.
apexi safc 2 .
custom made intake. with no idle control valve.
so here my question.. i need to find an alternative to regulate my idle . ( i need to give trottle ..because engine stall.) i try to ajust the screw on the trottle body but its not work... trottle flap need to be fully close at idle.. do you think ist an idea to drill a calibrate hole in my trottle body flap to give some air for idle just perfect around 1000rpm??
2jzge
tt head gasket
7m coilpack.
7m trottlebody
7m Knock sensor.
apexi safc 2 .
