It does if you do it right. Get a Toyota overhaul kit, it will come with all the rubber boots (including the slider boots). Most of the time when they seize up it is because the rubber boot has broken and the lubrication inside is all gunked up.
Remove old slider pins, clean, check for wear, clean, relubricate, replace all seals. Good to go.
