Built motor: JE pistons/Rings .40, Eagle rods, cleavite bearings, ARP studs, 1.5mm titan MHG, new oil/water pump ect....
Intake: K&N air filter, modified autozone adapter plate
Exhuast: Stock elbow, ebay chinese 2.5" - 3.0" dp, cat with honeycomb knocked out, HKS sport 2.5" cat-back with the last section of pipe and muffler removed just coming out of the resinator
Fuel: Walbro 255 pump, new stock fuel filter
Ignition: NGK wires
Tuning: Apexi S-AFC (untuned, no wideband or dyno at the moment)
Turbo: Stock CT-26, TurboXcess MBC(set to around 10psi), Autometer Boost gauge
Suspension: Origanal TEMS(blown, so no spin just wheel hop)
Drivetrain: W-58 trans(the r-154 i had was toasted), Center Force Dual-Friction for W-58, Turbo 3.80 LSD rear end(it whines)
Tires: fronts Goodyear eagle passenger side/Toyo Proxies 4 driver side, both 225/45/16. Rears Toyo Proxies T1Rs, both 255/45/16s
