Before and After 1/4 slips
NeoJester
104
Emo
Before i removed rattling pulley causing knock sensor to pull timing:
After removal, hit fuel cut in second both times, unshimmed wastegate causing it to not hold boost till redline in first or second:
NeoJester
104
Emo
Built motor: JE pistons/Rings .40, Eagle rods, cleavite bearings, ARP studs, 1.5mm titan MHG, new oil/water pump ect....
Intake: K&N air filter, modified autozone adapter plate
Exhuast: Stock elbow, ebay chinese 2.5" - 3.0" dp, cat with honeycomb knocked out, HKS sport 2.5" cat-back with the last section of pipe and muffler removed just coming out of the resinator
Fuel: Walbro 255 pump, new stock fuel filter
Ignition: NGK wires
Tuning: Apexi S-AFC (untuned, no wideband or dyno at the moment)
Turbo: Stock CT-26, TurboXcess MBC(set to around 10psi), Autometer Boost gauge
Suspension: Origanal TEMS(blown, so no spin just wheel hop)
Drivetrain: W-58 trans(the r-154 i had was toasted), Center Force Dual-Friction for W-58, Turbo 3.80 LSD rear end(it whines)
Tires: fronts Goodyear eagle passenger side/Toyo Proxies 4 driver side, both 225/45/16. Rears Toyo Proxies T1Rs, both 255/45/16s
NeoJester
104
Emo
well the 15.3 run went like this. 3500rpm launch slipping the clutch boost hits 10psi and drops to 7psi take it to 6300rpm, shift to 2nd bam fuel cut cause it spikes and boost goes to 5psi take it to 6200rpm, shift to 3rd and boost goes to 10psi and holds all the way till 6400rpms as i crossed the line.
NeoJester
104
Emo
i heard there is an open ay at the track on november 11th i hope to run again. Today i shimmed the wastegate 5mm, and did the AFM mod drilled the plug and turned out the screw. I redid the boost on the boost controller so it hits 14 now with no fuel cut, still drops from 14 to 11 in first and 14 to 11-12 in second and 3rd 4th and 5th all hold 14psi while at wide open throttle. Also the spool time is drasticallly decreased. so we shall see what she does. Im practicing my reaction time and my launch as well. Might be wishfull thinking but i hope to break into mid 14's if i get to run once more this season.
gixxer750
2jzget comingsoon!
Mississippi
I think the mph was low. still something wrong with the car. I'd look further. With a stock gutted downpipe, 10 psi, intake, and fat tires, I did 13.9's @ around 89 mph.
NeoJester
104
Emo
i couldnt really launch the car cause it would wheel hop do to a shot suspension., and with the rear end whining id be worried that wheel hop would blow it up.
dbsupra90
toonar
indiucky
see look at the difference launch makes!
2.4 60' = 15.769 @ 87.71
2.09 60' = 15.34 @ 87.71
btw, 2.09 is respectable on street tires with our car, esp with someone new to the track.
keep at it! now that the fuel cut is sorted i'm confident you will be in the 14's at 90+
