aftermarket cams in a 1jzgte
zac101191
57
wheelig
I have a 1jzgte and im gonna get 264 cams and adjustable cam gears. I was wondering how do I time aftermarket cams would I just zero them out like stock cams. How would I go about doing it??
scottiedawg66
Bay Area Ca
Fwiw I run my "small core 272s". (Lift similar to most 264s, but 272 duration) With stock cam gears. I only pull about -13 in at idle. my powerband is not great, I wish I went with machined usdm 2jzgte cams.
The local 2jz tuner has played with cam gear adjustments on the dyno and has been able to change the mid range and response a bit, but peak power never really changed with cam heat adjustments in his tests.
Bigger cams need adjustable cam gears and need to be degreed and set to the proper place with the cam gears in order to get them to work as designed. You will see poor results without doing so.
zac101191
57
wheelig
Ok I've never installed cams before obviously could you send me a min with the right tool ill need to degree it with
Youtube how to degree cams. there is a video with a 2jz. same as 1jz.
also you will need to check and adjust the valve lash on each valve when installing the cams.
zac101191
57
wheelig
Yeah its the same as my old ltr 450 four wheeler shum and bucket just never installed a cam in a car let alone an aftermarket one shimming is gonna be the easiest part lol. Just need to study more on the degree part. Thanks for all the help
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
what's said above is true to some level and great rule of thumb, but from experience not degreeing cams means a lot less than you may think.
for instance, with the GSC and BC cams we installed on various customer 1J/2J cars (when I was still working in FL) we didn't notice any real change using the cams with stock cam gears set to the same positions as the stock units. they still made great power as long as they were properly installed.
however, it really depends on application and manufacturer.
zac101191
57
wheelig
Ok cool I was gonna go with BC 264 but I might go the 2jz route have the been proven for better results than 264
zac101191
57
wheelig
Doesn't seem like its even worth my time to put 2jz cams in my car. I got the head off the car I'm gonna do a port and polish new valve seals arp bead studs and cams. Does a 2jz head gasket fit on a 1jz its hard to find a 1j head gasket
scottiedawg66
Bay Area Ca
Peak power will be better with 264s compared to 2j cams. But the response and low mid range will be better with the 2j cams. Now that i am drifting i want the low and mid range response.
zac101191
57
wheelig
Makes sense. I want peak power so I'm just gonna go with Brian crower 264s and have them degreed once I install them. My goal is 450whp gotta single 6262 walboro 255 12v mod aem v2 630cc injectors and pulled the motor to clean it up for spring so decided to do a little head work
seoul4korea
620
San Diego, CA
www.supraforums.com
Yeahh it depends on what you are really looking for, I was changing my valve stem seals and found a set of 2Jz cams from another member for $125 that where already machined and threw them in. Granted it may not have give as much power and such but I only spent like less than $200-$250 on the seal change and cams. I recommend changing valve stem seals, if you don't want to buy the tools you maybe able to "borrow" some from a member on the forums, I paid for shipping and a guy lent me everything I needed.
zac101191
57
wheelig
I ordered my stem seals the other day and I already have the Toyo tool and pliers for the seals. If I could fine already machined cams I would do that for that price too. What clutch do you recommend I think I'm getting a act xtss seems suitable for what I want
zac101191
57
wheelig
damn nice. Where can I buy shims from for my car I cant find anywhere. Are my shims the same as a 2jz and if so cant i just get them from the toyota dealer
