92 SC300 Build.
highmilehatch
PA
www.street-solutions.com
I purchased this 92 5 spd. SC300 about a year and half ago. I've been slowly stockpiling parts for it and recently got started. Here are some progress pics:
Car as purchased with 143k on it.
1995 Aristo front clip. Almost looks to good to remove.
Rear sump setup purchased ahead of time from a GE ready to modify for oil return.
Done.
Front and rear sump comparison.
Installed.
Pickup gasket.
TT Supra water pump with backhousing.
US spec Supra twins.
JDM spec Supra/Aristo twins. Note the lack of exhaust bypass tube.
Comparison shot of turbo outlets where downpipe mates.
US
JDM
Brand new OEM TT Supra oil return rubber.
JDM vs US EGCV.
Brand new Toyota/Lexus lower control arm bushings.
Old bushing removal.
Pics of the wiring harness I built. The most time consuming process of the swap. I started with a spare SC300 5 spd. wiring harness. I then broke it down and added the appropriate GTE electronics and wire harness plastics from the RHD Aristo harness to look as factory as possible. Here you can see starter, DIAG box, evap vsv, ED ground, and oil level sensor all exiting the harness behind the intake manifold like factory.
Here you see SC300 fuse box wiring in top left, GTE igniter wiring bottom left that was added. Igniter will rest on driver side shock tower just like a factory Supra TT.
Injector 2-6, cam, MAP and IAT sensors.
US spec twins installed.
Wiring harness, turbo heat shield and upper plenum installed.
A Lexus needs a nice interior too.
Rears are currently done.
Car will be getting the full 97 and up conversion and fresh Garnet Red Pearl paint.
OEM Toyota Soarer R154 shifter extension parts to fit R154 to SC just like factory.
99+ SC/GS/RX steering wheel. Still searching for that airbag.
Brand new OEM 97+ tails.
Denso TT fuel pump.
97+ OEM spoiler.
Vintage Work VS Edition wheels.
Precision 600hp intercooler. All piping will be custom by me.
R154 transmission. Clutch is undecided.
I'll update more as I go. That's all for now!
BrandonW
1,300
N.J.
nice you made a build thread, cant wait to see this done
when do you think you will be ready to pull the ge out?
highmilehatch
PA
Brandon, I can't either. I'll hopefully have it out within the next few weeks.
IJ.;1668780 said:
I like the 96/7 front much better than the plain catfish looking early front!
Moved to "other cars"
Yes! I totally agree. The car looks much more like a more "modern" car with the 97+ parts. 92-6 just looks too old and bland.
A bud here has a 96/400 with that front another has an early Active car with the catfish front, no comparison :)
highmilehatch
PA
I got the new leather from leatherseats.com They were blowing out some of the tan interior SC300 kits on ebay for $0.99 starting bid and no reserve. I got a set for $335. They sell on their website for $699. I just waited it out.
highmilehatch
PA
I have a friend who has 8 years of work experience wrapping them, so I paid him to do the job. Rears were done last weekend, today he should be finishing up the fronts. I'll post pics when they are all done.
highmilehatch
PA
Found some more time to work on the car.
About to head in to shop to pull engine.
On the lift.
Everything removed and ready to come out.
And we're out.
Back outside for a wash.
Dirty bay.
Clean bay.
Back inside.
GE next to GTE.
Spec stage 2 for the W58. Less than 1k miles and cost $150.
Trans back on.
And we're in.
Hopefully I'll find time this week to get it up and running and start building the intercooler piping.
highmilehatch
PA
The car cranked and started on the first try. Got the thing running to move around the shop. Intercooler has been mounted and bodywork has begun.
Mockup of hot side piping
Tigged and done
Temporary mounting.
Test fit of front bumper. Intercooler does not hang below and will use all factory ducting and shrouding. No need to move coolant reservoir either like alot of the off the shelf kits do.
That's how it sits for now. I'll be finishing up the cold side piping this week.
By the way. I need a TT Supra clutch fan blade. If anyone has one for sale, PM me.
