87 7MGTE No Spark; In desperate need of help in NORFOLK
Mueller87
Norfolk VA
3p141592654;1930541 said:
Well, its possible the wires were changed, but I doubt it. You're not the first person to have 3 CPS wires that look the same color. Usually the colors are preserved for the piece of wire shielded inside the CPS (assuming the CAP wasn't lost by the PO), so that is one way to figure it out.
G1 and G2 are the two diametrically opposite coils. The NE coil is the different looking one between the other two. See the attached photo.
View attachment 66492View attachment 66493
THIS IS PERFECT!!! thats exactly what I needed to see. Thank you very much.
Mueller87
Norfolk VA
just took these
here's my question though... if the two cps's I have are indeed from a 1987 supra turbo, same as the one in the picture 3p14 posted, then why is it that the wires are a different color from the harness? I mean it seems pretty clear that the white wires I have are grounds. and then it only stands to reason that the colored wires are the important ones. I can get a ground anywhere but If I have red green and yellow vs red blue and yellow How do I know which one goes where? see the bunch of wires coming out of the CPS is CUT. the wires for the CPS coming from the harness are CUT. they colors do not match...
by the way, I have no intention of troubleshooting the EFI system before I have spark... unless for some odd reason the EFI system has to be 100% for the spark to occur. Then I'd start there. But to me and in the case of anything I've done before they were independent on one another.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
What you're doing still needs to be fixed but without +B (which is ECU main power) the CPS signals can't be processed. Bottom line is at some point you'll have to get the MIL working. You're going to need a meter, know how to use it, and be able to read the schematics. If you can't do that it's going to be a struggle. Refer to 3p's excellent advice in post 20 as a start.
Mueller87
Norfolk VA
so the fuses are good, and I'm moving onto check the 'b+' lines. Im hoping that as much as everyone has helped so far someone won't mind telling me where and how I check this. I know I can do it with my test light, and I have to assume its inside the tiny diagnostic port on the inner drivers side fender. I already tested them all with the ignition on and I got voltage at one spot, So if I'm in the right spot I guess I need to see the identification of these ports. I've seen it before but now I can't find it...
Edit: I found B+ and this didn't have 12v. I will double check but I only had voltage at TS.
Mueller87
Norfolk VA
With B+ confirmed DEAD, that puts me dead in the water. If anyone could tell me what this B+ terminal represents, that would be awesome. In the morning I will pick up a multimeter and start getting serious about this.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=47
So I'm assuming that and the following two pages are undecipherable?
The ignition switch sends 12 volts to terminal IGSW on the ECU. Since the ECU always has battery power on terminal BATT, 12 volts on IGSW causes it to "wake up" and output 12 volts on terminal M-REL. That turns on the Main Relay in the underhood fuse box.
The relay closes and send 12 volts (this 12 volts is +B) to terminals +B and +B1 and to the diagnostic connector. Once the ECU is powered it outputs a ground on terminal W. This ground illuminates the MIL. Assuming the lamp is good this is why the MIL can be used as a indication +B is present.
When the ignition switch is turned off and the 12 volts on IGSW goes away the ECU takes a few seconds to home (fully open) the idle speed control valve and afterwards shuts the Main Relay off, killing power to itself. It then "waits" for IGSW again.
IndigoMKII
2,181
Madison, Virginia
Well said, not sure if it could be put into any easier to understand terms.
I know when we had a situation like this on my friends car, his kick panel fuse box had fuses in there that weren't touching both sides of the terminals. We had double and triple checked them but didn't think to make sure they were all touching, so after some frustrated wiggling of everything, the CEL came on with the key switch on. We just ever so slightly bent the tabs on the fuses to make sure contact was made. He had power to B+ though.
SC61 MK3
316
FL
To the above comment about checking fuses, I always give each fuse a little push to make sure they are in all the way. Than have my multi meter negative probe to a known good ground and use the positive probe to check voltage on each side of the fuse one at a time instead of just check continuity, which will only tell you if the fuse is completely blown where this way will verify the signal is actually running through the fuse like it should
