figgie said:ps the stroker kits make the rod 6 inches in length instead of the 5.8 inches for stock.
also i was joking with my stroker comment as i have had one for about two years. Same kit adjuster has. 8500 rpm redline without issues or failures.
bluemk3 said:does any one know of a stroker kit availible for the 7m gte
supramic said:just wondering is there really a de stroker kit out there or being worked on??
bigaaron said:Really? Is the pin moved up in the piston? Otherwise I don't see how that would be possible? When you increase the stroke the rod would need to be shorter.
But the differences we are talking about here are relatively small, it's not going to make a huge difference either way in terms of reliability. I hear some drag engines have a ratio of 1.5!
tekdeus said:Their ad says "That's a 115cc+ increase for Turbo motors!"
$3000 for 115cc? No thanks.
figgie said:apparently you haven't seen what Titan, HKS charge for the 2jz stoker kit 3k is CHEAP by comparo. And with our stroke. those .2 liter extra is night and day diff on off the line take off. Hell with the stock gearing (3.9 or 3.7) 1st and 2nd become worthless. With 4.1 three gears become nothing more than a worthless smoke show!!!
