hello forum i have quite the problem and im stumped ive tried everything to my knowledge , i come to seek help as i skim these forums and theres alot of knowledge here, ok so here the problem , i got a 1jz in a s13 240 single turbo, car runs great but when i get on wot u feel the ecu pulling timing like crazy! u hear the turbo spooling 15psi but the car goes nowhere i know its pulling timing, now thats with the cam sensors connected, if i disconnect the cam sensors while the engine is running it pulls like a train! im assuming the ecu is running on base timing at this point wich is y i feel it pulling hard, as soon as i connect the cam sensors bam pulls timing has no power under wot, any help is appreciated below are my mods and things ive done to troubleshoot/diagnose to the best of my ability.
mods: 1jz jza70 ecu,440s,320lph,safc,brand new harness from wiring specialties
ok heres what ive done
•checked resistance of both cam and crank sensor hot/cold spec out fine
•checked resistance of both cam and crank sensors at the jza70 ecu plugs, got same exact reading as on the cam/crank plugs so theres perfect continuity from ecu to sensors
• swapped both cam sensors for known working ones from my 1j supra
•swapped ecu with known working jza70 ecu rebuilt by DM from my supra
• swapped out 3 ignitors
• disconnected the safc and ran on stock computer as I know safc pulls/advances timing when u +/- fuel , in any case it should be advancing as im pulling fuel not adding but checked anyway
that sums up the things ive done , to my knowledge there isnt any other sensors that deal with timing that would cause it to retard timing to that extent, please any advice on where to head next is appreciated, thanks in advance
