7Mboost said:Yes you will need to roll your fenders, SupraNick runs an 18x10.5 in the rear with a +22 offset and needed a lot of fender roll and fitment.
50% correct.
but im running 18x10.5 rear with +27 offset on Dunlop Sp9000 275/35 and rolling the fenders was NOT ENOUGH! my 4 fenders were CUT, Pulled 1", then welded back together and then sanded smooth and repainted.
fronts are 18x9.5 +27 offset with 245/40 up front.
here's a pic...http://www.supramania.com/forums/vbpicgallery.php?do=big&p=1715
nother pic next to Nino's car for comparison to stock. it's a subtle pull, which is what i told the body guy, to make it look as stock appearing still as possible...
![p678165_1.jpg](https://www.supramania.com/images/pb_archive/p678165_1.jpg)
Test fitting in the garage when i first got the wheels. u can see hwo far they stick out!
![p678165_2.jpg](https://www.supramania.com/images/pb_archive/p678165_2.jpg)
rear wheel:
![p678165_3.jpg](https://www.supramania.com/images/pb_archive/p678165_3.jpg)
after body work:
![p678165_4.jpg](https://www.supramania.com/images/pb_archive/p678165_4.jpg)
