17x10.5 will it fit
shaggyskadude13
AAARRRGGGHH!!!!!
May 16, 2007
Rockledge, Florida
I did a search and couldn't find anything on it (mabye I was looking for the wrong thing).
Will a 17x10.5 fit in the rear with a +27mm offset and what about a 17x9 in the front with a +26mm.
I was hoping not to have to roll the fenders. Im at stock height at the moment but i will be getting coilovers soon.
tissimo
Stock is boring :(
Melbourne, FL
woah.. youre in rockledge.. you just resently get your car? what color is it.. I might of seen it around.. I go to MI once in a while on fri/sat night..
shaggyskadude13
AAARRRGGGHH!!!!!
May 16, 2007
Rockledge, Florida
Its white, but I bought it with the blown motor so if you've seen it it wasnt me driving it lol. I bought it from a used car lot on us 1 about 2 months ago. I used to go over to MI with my Prelude but I havent been in awhile.
bowsercake
828
Irvine, Ca
You can run those 10.5" mustang rims but they will stick out an inch or so. If you cut and pull the fenders it might fit. If you are stock height you might not have problems.
twinturbozs
131
san francisco
Im running a 19x10.5 (+35) with 285's and my fenders needed to be rolled. The only way to get the +27 to fit, is to run with a narrower tire, such as a 265 or 255.
tissimo
Stock is boring :(
Melbourne, FL
I thought you said yours were +43?
twinturbozs said:
Im running a 19x10.5 (+43) offset, but used a 3mm spacer since going up steep driveways or very very hard compression it slightly rubs my rear coilovers.
twinturbozs
131
san francisco
Ive changed setups.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Yes you will need to roll your fenders, SupraNick runs an 18x10.5 in the rear with a +22 offset and needed a lot of fender roll and fitment.
