WONT START NOW HELP PLEASE!!
Status
Not open for further replies.
fastsupralife
20g turbo!!!
Sep 4, 2006
iowa
OK I HAVE 87 TURBO SUPRA 5 SPEED IT HAS RUN FINE SINCE IV GOTTIN IT AND ITS BEEN COLD HERE NOW FOR ABOUT 2 WEEKS AND THIS MORNING I WENT TO START IT AND IT TURNS OVER AND TRYS TO START BUT WONT SO I GOT SOME BRAKE CLEANER AND SPRAYED IT IN THE INTAKE IT STARTED ON THE SECOND TRY BUT WHEN I GAVE IT A LITTLE GAS TO CLEAN IT OUT IT DIED AND NOW IT WONT START AT ALL BUT IT STILL TRYS TO START I DONT THINK IT IS THE COLD START INJECTOR BECAUSE IT WANTS TO START AND IF IT STARTS LKE IT DID THAT ONE TIME IT JUST DIEDS WHEN I GIVE IT A LITTLE GAS CAN ANYONE HELP ME OUT PLEASE AND THANK YOU:1zhelp:
JAMES
MDCmotorsports
Indy 500
www.MDCmotorsports.com
I know your mad right now, but please use some grammer.
I got a headache just reading your post.
It sounds to me as if some sort of electronic part doesn't want to run now due to the cold.
I would assume its a fuel pump. Check to make sure you have fuel pressure first.
If you do, check to make sure you have spark at all 6 cyls.
After all that, reply back to us.
empera
Authorized Vendor
Philly.
CSI or might be the Igniter* i remember something similar happening to me, i believe it was the igniter, our electronics hate the cold ;)
dbsupra90
toonar
indiucky
crank and no start the first thing i would look at is the cps. jiggle around the wires and try again.
next, id pull off the oil filler cap and make sure the cams are spinning. could be a broken timing belt.
jumper B+ and Fp in the diag box and see if you have fuel flow.
check for any codes.
make sure all your ic pipes are solid along w/ the clamps/couplers.
fastsupralife
20g turbo!!!
Sep 4, 2006
iowa
ok it warmed up out side and my sister jumped my car cuz the battery was dead it started but ran like shit and was smoking then it died and it started right back up but died as soon as i touched the gas.. i was wondering if the plugs are cloged up cuz of all the trying to start it and what not could that be it now???
turbo4toy
208
Los Angeles
Pull a few of your plug wires and check for oil......the valve covers love to leak or depending on how much smoke the valve stem seals like to go after a while and its most noticeable when its cold.
Status
