wont start after HG job
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
hey everyone, i recently changed out my headgasket and now it wont start, wont even crank over. i have to use a remote start switch to start it before cause the key wont do it. but now after the HG job it wont even crank even with the switch, maybe i hooked it up to the starter wrong? only code im getting is 22 and thats fixed now. any ideas? thanks,
Zach
edit: lol also its crazy but the lights you turn them on and the bulbs turn on but the lights retract, but when you switch them off they flip up and bulbs go off... what is up with that? lol thanks.
hellraiser456
130
canada
sounds like you have messed something up in the wiring...and im going to say its more than one system.
i would first start by triple checking to make sure your alarm is hooked up right...sounds like the problem may lay there as they can be hooked up to the starter and light systems. i know they can do whacky things. i would also check to see if your start leads are all good as well with grounds. you miss a ground and wacky stuff will happen
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
well with the remote start switch... button whatever you want to call it, the alarm doesnt matter, most likely i missed a ground or something but thanks for the help.
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
are there any particular grounds or wires i should be looking for? lol turning the headlights on, only for them to go down is a little annoying lol. thanks for the help,
Zach
