Windows and electronic gauges failure
ryushi5
24
Louisville, KY
Today I realized that my Tach, windows, and guages for the temp, oil, and boost stopped working. I checked all my fuses as a first reaction.. but found nothing. Any thoughts on what I should check next?
ryushi5
24
Louisville, KY
Yeah, I had checked those. Maybe I just overlooked one. I'll have to check again. Also The climate control and lumbar don't work... I may just replace all the fuses to be sure.
Scruggs86.5T
298
Slidell, LA
My first thought would be the 7.5 amp gauge fuse, it controls your main pwr window switch also. But since you are saying you seat control is dead too than it could be the 30amp pwr cb under the left kick panel. Here is a link to what it looks like, #14
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=BE&P=13
and here is a link on how to reset it
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=BE&P=4
Also keep in mind that if it is blown there could be a reason that the CB blew. It could be a short somewhere in your system. I would try reseting it first and if it blows again there is definately a reason for it. Good luck. Also here is a link to the front page of the TSRM if you didnt have the link yet, I recommend making it a favorite.
