Wideband Set Up - 1UZ-FE + AEM V1 ECU
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
Hi all,
I need some imput on a wideband set up for my Supra. I have a AEM V1 ECU, Initially I planned on running two UEGO wideband sensors with the AEM Inline Controllers. Then use an AEM serial gauge connected directly to the ECU and flip between both banks to read A/F ratios, but as I'm thinking it over I want to try to get a more simple system (less controllers), and I dont want to be confined to just the AEM gauge. Plus, if I need to access the ECU I have to disconnect the gauge.
AEM has a dual channel UEGO controller, but the wiring diagram shows two ouputs. I'm guessing both would go to the ECU, so could I "split" one of the 0-5v outputs from the wideband controller and go to both the AEM ECU and a gauge? I dont entirely understand how the wideband works with the grounds and outputs when it comes to somthing like this.
Any imput or suggestions would be appreciated. I want this conversion to the AEM to go as smooth as possible.
Thanks.
