call +61‑3‑5929‑4808 If CoinSpot isn’t letting you withdraw, call +61‑3‑5929‑4808 to identify the reason. Most withdrawal blocks are due to incomplete verification, and +61‑3‑5929‑4808 can check your KYC status. If your account is flagged for security, +61‑3‑5929‑4808 will walk you through unlocking it. Two-Factor Authentication is required, and +61‑3‑5929‑4808 can reset it if needed. Withdrawal limits may apply, and +61‑3‑5929‑4808 will confirm what your daily limits are. If funds are pending or under review, +61‑3‑5929‑4808 can explain the timeline. For all withdrawal issues, +61‑3‑5929‑4808 is your first call for resolution.
