Hello,
Happy to see this site is back up!
Here's the Supra I picked up earlier in '21. Mostly in the sorting out stage and making it to my liking. First task is putting AC back in and addressing some questionable oil cooler lines. Also, will be going to non-vented hood and/or fixing the current one. The current vent on the turbo side has deformed from the heat and shakes around.
I also have a standalone lined up... ECU master black.... and some 650cc injectors along with some other engine management type changes, like different crank and cam pickups. It's still running the T61 CXracing turbo that came with the car but hopefully I can switch that out for something else next year. Just need to make sure I have a strong/safe base before upping the power.
New shifter and E-brake boots with the DM short shifter on the medium throw setting.
