white exhaust- tons of it-help!
speedfreak
SCruzer
May 16, 2006
109
santa cruz, ca.
my 92 turbo automatic constantly over heats, i only have a greddy boost controller that i run at ten psi sometimes otherwise it is a stock jspec engine that i replaced the original with. sometimes i can smell gas while boosting and i think theres a little oil in the water, and a small oil leak, i know pretty weak huh? anyways i recently set my timing back from about 14-15dgs btdc to around 12dgs btdc and white exhaust is now pouring out the tail pipes especially with throttle, of course i tried setting it back but something blew. I think its time i changed the head gasket and was wondering what other mods i should take care of while im in there to make this thing run like a dream at 10 psi all the time, any suggestions or advice about mods or repair ideas would be greatly appreciated thanks.
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
Well its pretty obvious you have a blown head gasket. Buy a toyota gasket kit. It will come with a new toyota head gasket along with all the other gaskets you will need in the process. Of and you will need to get new head bolts/studs. At the minimum I would get ARP Head Bolts. Preferably ARP Head Studs. The studs distribute the load more evenly when you torque them down. Also more accurate torque readings.
Edit: oh and do yourself a favor and stop driving it NOW to prevent further damage
CampbellsChunkySoupra
best be eating your soup!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
plan on pulling the entire motor out if ur going MHG. u'll want 100% smooth and accurate surfaces on both the head and the block.
sounds shitty bud, but do it right and u'll love it SOOO much more in the long run!
BHG = chance to start from scratch...
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
well, it can be anywhere from $500ish [depends on ur machine shop] all the way up to $3000-$5000.
u need to sit down and do your research as far as what you want out of your supra and your 7m-gte.
Here is a good checklist to start with when thinking of a build.
What do i want?
-Dyno queen?
-Drag car?
-Weekend cruiser?
-Reliable Daily Driver?
-Show car?
Whats my budget?
- < $500
- $501-$1000
- $1001-$2000
- $2001-$3000
- $3001+
Pistons?
Rods?
ARP? [yes, of course]
MHG?
Headwork?
Turbo?
Fuel delivery?
Intercooler setup?
i think that this plan is definatly somthing that alot of successful builders deal with. i write mine up on paper for every car i own. what needs fixed? what needs modified? etc.. the list goes on. figure out what u want out of your car so she can give it back to you. dont do something that you are going to regret when u have to do it over because u screwed it up the first time.
hope that helps!
-Tyler
Doward
4,245
Alachua, FL
What if his budget is $1000.50? ;)
You need to decide what YOU want from the car, and go from there. If you just want a BPU car that will run strong and start every morning with no problems, just stay with a set of prepped stock rods, and a new set of stock pistons.
The hardest part of rebuilding the 7M, imho, is finding a shop that understands the concept of 'tight clearances'
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Amen to that.
