Which gasket maker to use Please Help
Nate
GSWAG
Dec 26, 2006
31
Queens
Im installing a used cat back exhaust,I dont have any of the gaskets that go with system Can I use one of those gasket makers like permatex?
mkiii222
Troy, MI
I'm using the same stuff (Permatex 700F copper) on both sides of my test pipe. It's been there over a year with no problems.
Supracentral
10
CyFi6;1312569 said:
Donut gasket+ copper rtv does it for me. I dont think i would put a flange up to another flange with no gasket and just RTV
As much as I hate to admit it, I've done it in a pinch. It works, it's ghetto, but it does work.
Nate
GSWAG
Dec 26, 2006
31
Queens
So I could use just the permatex without any actual gaskets right?
Supracentral
10
You can, but it's not the best thing to do. If you can get a gasket, you should use one.
Nate
GSWAG
Dec 26, 2006
31
Queens
MKiiiturbodrift;1313278 said:
Just get a donut, its much easier and only cost a few bucks.
Does anyone know where I can buy the square gasket as well as the 2 bolt,I checked suprasport,suprastore and horsepowerfreaks and only suprasport has the 2 bolt but no one has the square one
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
that is new
the cheepest gasket you can make is the copper stuff and a pop can
or cerile box
cut 2 squre shaped flanges rtv them together and add it on the other sides takes heat well other and seal's very well and piss ass easy to make
Nate
GSWAG
Dec 26, 2006
31
Queens
NashMan;1313907 said:
that is new
or cerile box
Does anyone know where I can buy the square shape gasket I saw a hks exhaust system that has the same shape but I dont know if the sell it by itself
