When advancing the timing...
Dragk913
Broke Supra Owner
Dec 26, 2006
154
South Houston, Texas
I want to advance my timing to about 14 but after reading/searching I still need some help. Do I set the crank to 14 [instead of 10] or do I set the distributor? or both?
Sorry if the questions seem lame, I just need some input.
Thanks!
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
you have to have the car started and a timing gun, then just turn the distributor as needed and use the timing gun to check where the crank is at
Dragk913
Broke Supra Owner
Dec 26, 2006
154
2543arvin said:
Well then, why are you trying to advance the timing?
Because I want to squeeze a little more power out of an N/A.
And when I said "I'm not the best mechanic" I just meant my experience is lacking. My actual work is rather decent IMO, because I rebuilt my entire motor mostly, by myself.
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
Get a timing light connected and start the car. Jump the two pins on the diagnostic connector (sorry, can't remember if it's T and E1 or E and T1), loosen the distibutor adjustment bolt, and turn it until you have 12-14 degrees BTDC. Make sure you run 91 octane fuel you will be worse off than when you started.
Dragk913
Broke Supra Owner
Dec 26, 2006
154
Awesome. thank you so much BlackM!
