Stock fuel pressure is aprox 35psi correct? Is it better to be able to run on less fuel pressure and achieve the correct A/F ratios or should I just keep it at 35psi no matter how rich my mixture is?
Also what's the maximum fuel pressure you're able to get?
I just installed a walbro 255 with stainless braided hose, bypassed the J-tube and I can only get a max of around 42-45psi at idle.
I'll be upgrading to 550 injectors + MAFTPRO next week, will the 550's allow the fuel pressure regulator to pull more fuel past what I can get it now, or is that restriction based on the fuel pump or something else?
Thanks.
Thanks.
