What rwhp is the stock exhaust manifold good for please guys?
Toy-Rific
145
Minnesota
Here is a list that we use at SupraSport for a good start point
Recommended supporting mods needed to support Boss Series Turbo's.
High flow intake (Apex-i, Blitz, K&N, SS Intake Kit)
3" Mandrel bent cat back exhaust (RS-R, Blitz, Tanabe, etc.)
3" Test pipe (check state regulations) or cat (Random Tech, Vibrant, etc.)
3" Down Pipe and Elbow (RT, LIPP, Cooleeze, Tanabe)
Walbro 255 fuel pump or larger
Fuel pressure regulator (Aeromotive, SS General Install)
550cc or larger injectors (RC, PT, Venom)
LIPP or Lexus AFM upgrade with Apex-i Super AFC-2 or other similar engine management (MAFT-Pro / MAF Translator with GM Blow Through AFM, AEM-EMS, Greddy e-manage)
Wide Band o2 Sensor kit to monitor EXACT air & fuel mixture from exhaust After but closest to the turbo usually side by side with the stock o2 sensor (the stock o2 sensor system will need to remain installed and DO NOT TAP INTO THE STOCK SYSTEM the main computer still needs this, the wideband has its own controller) (NGK AFX, AEM UEGO, Innovate Motorsports)
Full intercooler hard pipe kit 2.5" or larger
Intercooler
Blow off valve (single or dual Bosch option will not be sufficient, should be on of the major brands)
Greg/Lipp
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
1.) Stay away from Venom injectors, there is another thread on this right now.
2.) The wideband sensor needs to be installed at the recommended length away from the turbo that the manufactur of the sensor suggests. This is typically far away from the o2 sensor and not right beside it. Will it work? Probably. Will it last long? Probably not.
Greg, how's the LIPP exhaust manifold comming along?
Toy-Rific
145
Minnesota
Thanks for asking. It is still not ready. I have started tooling for a new turbo line for the T4 housings. There will be a .58 and .70 and .81 and .96 AR. They are going to be a light weight unit and will have on the exhaust side a v- band in a 3" or 3 1/2" or 4" size for each AR. This has been taking almost all my time in the shop. Hope to have machined castings the first of Jan, 08.
Greg
Lipp/SS
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
Intercooler
Greg/Lipp
say with all those supporting mods above and a good tune what kind of rwhp can you guestimate?
i ask because i have all that and more goin into my build and i'm just curious...
EDIT: i'll be running with the JT61GT turbo =0)
thanks, t3d
supra1
Supraholic
Oct 19, 2007
58
EwwK
Intercooler
Greg/Lipp
Great info
Thanks guys
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Greg
Lipp/SS
The machine castings that you are talking about. Are they for the bolt-on BOSS turbo, or something else? I was under the impression that you were making a replacement manifold that would bolt onto the BOSS turbos and others that have the same footprint as the CT-26...
Toy-Rific
145
Minnesota
The exhaust manifold will be the same as the stock one that the CT-26 and the Boss fit. The new housings are to cover a larger buying base of after market turbo's and will not be made to fit the stock manifold.
Greg
Lipp/SS
Toy-Rific
145
Minnesota
thanks, t3d
I don't know what exhaust wheel the 61GT is using, I would think it is a stage 5 or a P trim so you should bi around 600hp but this is not a for sure number just a shot in the dark
Greg
Lipp/SS
Toy-Rific
145
Minnesota
That HP power rate is on the crank and not rw, so you will have less power to the ground. I don't know what the loss would be on your car.
Greg
Lipp/SS
