What mhg to use on shaved cylinder head and bored block?
478slimm
58
Georgia
I'm almost done with my rebuild but I have no clue of what MHG to get. The head has been shaved 0.10 and the blocks been bored .20
I'm seeing a lot of 84mm and 86mm, witch one and how thick??? Looking for 400hp
Mods: cylinder head shaved, ported and polished.
Stock rebuilt ct26(until I put a few miles on the car and see she's holding up)
550cc injectors
Lexus AFM
320lph fuel pump
Greedy emanage or Aem Fic 6(Not decided yet)
Suprapowaz!(2)
2,870
San Antonio, Tx.
Head has been shaved 0.010. Block was bored 0.020 (0.508mm) on an 83mm piston is 83.5mm. You should be safe running an 84mm gasket. As far as thickness... http://www.supramania.com/forums/sh...ess-selection&highlight=head+gasket+thickness
So... if your head or block hasn't been touched and you've only shaved 0.010 (0.254mm) on the head then... do some simple math.
And it's "which", not
images
