What is this sensor?
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
so im trying to take my wiring harness off, and theres one last wire going down under the heat shield of the exhaust manifold.. it might be some sort of oil pressure sensor or somethign? anyway how do you get it off?
walka
46
beltsville, MD
the one with the black cover over it?...the oil pressure?
if you remove the black cover its just a pull away from comin off if thats the one
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
no no i cant actually see the sensor.. i just see the wire (which is encased in some kinda of protective insulation) and it goes into behind the exhaust manifold heat shield at the ront... its at the very end of the wiring harness..
