What is the best way to remove old tint?
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
I have old tint on my windows and its bubbling and dry, stuck real good does anyone know a good way to get it off. I used a razor blade but that dont work to good. John
JENNY!
Supracute
Mar 29, 2006
224
Dublin, CA
if you search, you will find something.
cover interior with trashbags, spray amonia on the window, tape garbage bag around window to "bake" let sit for an hour, scrub off. DONE.
Make shure its warm outsite.
HIDPLANET
89 1JZGTE
Yeah my tint was way beyond the point of no return.
I did the amonia baking method and it couldnt penetrate the 15 yr old tint so I had to resort to using a blad on the entire rear window basically ruining the defrosters but its no big deal to me because I dont use them. Im in CA and plus I wont be driving the car in conditions where they would be needed.
fstoy
Soon to be Evil Twin
Texas
try peeling it off. Get some single edge razor blades and some 409.
Spray the 409 on the left over glue residue, then scrape with the razor blade. Only takes a few min to get clean.
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
Thanks All i will try them all as long as it comes off. Its 30 degrees here now so i cant really do the garbage bag trick till it gets warmer.
catback
bitterville
i do alot of tint removal and i found that a heat gun and scraper wwork the best.:icon_bigg
just be carefull in the rear hatch, make sure you dont scrape the defroster lines off:nono: ask me how i know.. actually dont it cost me $1000:cry:
Justin
Speakers?
Spokane, Wa
I've had a shop work on my supra two times while i've owned it.
1. remove my tint
2. flush my radiator
I did my front two windows with a razor blade... easy.
The rear three SUCKED.
I tried, I spend about 3 hours working on the rear. Then I paid a shop 20 bucks and they did it in an hour. wo0t!
