what are these for???
porsche6016
47
e-burg
putting motor back together after replacing the head and i fall upon 2 wires that seem to have been ripped off from the connector from the privious owner when he started tearing it apart.... one i know is for the rear knock sensor... there are also 2 connectors i don't know where they go...
driver (intake manifold) side
the whiteish gray connector, the brown one goes the the upper manifold and the grounds go to the bolts but where does that connector go??
what this connector is for??
passenger (turbo) side
and i'm thinking this is the other part, which comes from the wire harness near the thermostat
iamshawn
codename: HENRO
Nov 2, 2005
74
Houston
on the top picture the brown one is your starter signal wire. and the one with the ring on the top there is for the power to the starter. The white one goes to the abs from the transmission.
can't really see the plug in the second picture maybe a close up would be nice..
that yellow one on the last picture is possibly your oil pressure wire ripped off...
