weird timing
themadhatter
760
Vegas
so i was outside today setting my timmng and it seemed weird i had to turn my cps as far as it could go to one side to get 10 deg. for timming any one got any ideas?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Which plug were you using? 1 or 6? Assuming the car runs OK then likely the CPS wasn't installed right. Pull and reset it. Easiest way is to draw match marks across the G pickup and housing then reinstall as centered on the slot as possibly with the match marks aligned. Re-time afterwards to get it nuts on. And by no codes I'm assuming you got code 1.
themadhatter
760
Vegas
yes the light just blinks 1 time fast like it does when nothing is wrong. I used the first cylender closest to the crank pully i asume that is the number 1 cylender. I guess when i shim the waste gate later this week i'll pull the cps and double check that it is aligned right but i'm almost 100% it will be seeing as how i reinstalled it lest then a month ago and remeber alighnng the cps like te tsrm says
