water rushing noise
max-89supra(t)
153
vancouver, wa
hey guys,
today evening i was at a stop light, i slightly revved my engine and heard a water rushing noise from around the fire wall, ive had that before the rebuild once in a while. now i have an hks mhg, arp head studs at 85lbs, head and block were resurfaced, after that i never had that sound come up again till today, only did it once and thats it, no matter how i revved it didnt do it again. does this sound serious to anyone?? should i re tourqe the head bolts??
any help is appreciated. thanks
gaboonviper85
3,236
Northeast Philly
That water rush noise is air stuck in your heater core....either you have a pinhole leak in a hose or something that is sucking air or you are low on coolant.........ooor you're blowing exhaust gas into your cooling system...
When you revved the motor you cleared the air from the core which is why it didn't do it again...my supra has been doing this for over a year and I personally ignore it as I don't plan on driving it much longer.
soc chaos
Oklahoma
yeah I have this as well I figured it was the hose I had to re route from the passenger side to the inlet on the firewall. Still not sure which it is considering sometimes I hear it sometimes I dont but mine sticks around until third gear.
jtran8
199
wichita kansas
My supra used to do that every time i changed coolant , I cut gigle valve off thermostat and never have that proplem anymore . You can jack front end up and burp coolant system but remove gigle valve is a better choice ( Jdub and IJ v'e done that too !:icon_bigg
FernandoDLT
357
Texas
I've noticed this on my car as well. Does it when the car is cold or when I use the heater. Never does it while the AC system is on.
Fernando
Sep 10, 2007
482
Virginia
I always have a problem getting all of the air out of the cooling system on my car after having to pull the radiator or changing the coolant. I just bought this to try and solve my issue, a spill-free funnel kit to burp the system:
