viper 5900 in a 87 na???
taka21
363
washington dc
ok ive searched through the site for a few days now and i cannot find a wiring diagram for a pre 89 mk3
im looking to see if anyone has installed a viper system on a pre 89 and how they did it
the wiring diagram for the 91 looks different and im a little confused
any help would be great and greatly appreciated (im trying to learn how to do this install)
thank you
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
have u looked into the MK3 Supra TEWD yet? when i installed my car alarm i looked into these sections:
Toyota Theft Deterrent (to bypass the stock alarm)
Door integration? for the door locks
Ignition and starting for the remote start (if applicable, also for the starter disable)
Interior lights (if alarm has dome light supervision)
Blinkers (i wired mine to the hazard switch, there were two brown ones, just use multimeter to find which side is which)
Door pins (i wired mine to the interior lights, instead of adding diodes to each pin, so whenever doors open when armed, alarm goes off, easier to do!)
btw heres the link to the TEWD, good luck, if you have any other questions u can ask me, i may be able to help with other stuff that isnt provided on this link:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=123
taka21
363
washington dc
you rock thank you so much
taka21
363
washington dc
im still learning how to read actual wiring diagrams so its only so helpful to look at them. so far i ve layed out all the components to the system and figured out which harneses i will need and which ones i wont, i have also removed all the panelling and gained acces to all the areas i need to wire into , im trying to figure out where to really start as far as splicing things in
taka21
363
washington dc
ok so i wired everything in using the guides i got from 12 volt forums and the viper guide but the door locks dont function from the remote and the parking lights dont flash, basically the stinger is the only component that sets off the alarm
what did i do wrong
