So I discovered yesterday that I have a bit of an issue -- with my FFIM and the linkage on the inside (as well as the wiring harness), I have no room to reinstall the hose that runs from the Driver's Side VC to the side of the block. My question is, can I use a different hose that size instead? I figure if I can find a hose that side with a 90* angle, it can slip right down and pretty much run straight into the block fitting...that, or run standard hose that size out and around the neck of the Intake and back down...which would look kinda tacky, actually. I guess my question is, what have some of you done (if anything) to remedy this? Pics are below of my layout. Thanks!
