Where is the correct location for this tube:
Here's where I "think" it is located:
Approximent location:
This is between the second and third intake runners Yes, I know it has to be mounted on either the head or intake manifold, if this is true then I sure don't recall it being mounted up so high even after it's in it's correct location.
True/ false: this vacuum tube operates the B.O.V. and attaches to the head or intake manifold and then to the "L" shaped looking vacuum manifold, underneath the intake runners and should be the third port counting from the left, (horizontal tube) excluding the verticle portion of the vacuum tubes. Thanks!
This is between the second and third intake runners Yes, I know it has to be mounted on either the head or intake manifold, if this is true then I sure don't recall it being mounted up so high even after it's in it's correct location. True/ false: this vacuum tube operates the B.O.V. and attaches to the head or intake manifold and then to the "L" shaped looking vacuum manifold, underneath the intake runners and should be the third port counting from the left, (horizontal tube) excluding the verticle portion of the vacuum tubes. Thanks!
