Vacuum hose
ToyoHabu
261
Huntsville, Alabama, United States
I thought that I took enough pictures to figure out the vacuum hose routing. :dunno: however I doent think mine came with routing correct. One of the turbos' had its waste gate hose blocked off. Each turbo has a waste gate actuator right? where do these attach ? directly to the port at the compressor exhast ? This engine came with a ARC BOV where should it connect? and finally there is TWO pressures sensors where should the second attach? the first is on the backside of intake plenom on the engine side. perhapse someone could send me there pictures, or has the diagrams maybe ? anyhow any help would be great!
