Vacuum Hose I.D. and O.D. Info Needed!
Kai
That Limey Bastard
Before you ask, yes, i have searched. Looking for the sizes of the vacuum hoses, as i've heard different sizes floating around.
The longest 'run' of hose is apparrently 3.5mm, but i cant find any, theres 4mm all over the place, is this the stuff i need??
I've got no idea where to look in the TSRM for this kinda stuff :/
Kai
That Limey Bastard
yeah thats what i've seen before, but no one stocks 3.5mm hose....3mm and 4mm, but no 3.5mm....
Onlineconversion.com says 3.5mm = 0.1377" = 1/8th Inch, which loads of people stock, and others call 3mm....is that right??
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
lol I'd think that would work. I dont see why not if the conversions equal each other. If you really couldnt find the "true" 3.5 anywhere, just get a tiny section of the 1/8", run out and check it on the engine quick.
Kai
That Limey Bastard
Well the engines coming out for the impending rebuild (hopefully before the 27th May), so i thought i might clean the engine bay up, clear up the wiring loom, remove the shitty looking connectors, patch in new wire for the coil pack etc, and replace the worn looking and dirty vacuum hoses, make it stand out a bit.
Jeff - if you're still reading this thread, do dealerships stock the plugs for the coilpack and the CPS?
