Using the 2j oil pressure sensor
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
so as some may know im going na-t with 7m electronics. my question in this: i know we are supposed to use the 7m ops, and i know it must be extended out in order to not get in the way of the block. my question is this: can i use the stock 2j oil pressure sensor and just switch clips? im guessing it will give a different reading than the 7m one. can i 1) wire in a resistor to counter it or 2) screw the 7m ops into my oil sandwich plate for oil pressure. thanks
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
2JZ is a pressure switch (on/off), 7M is for the gauge (Resistance range). Yes you can run it off of the sandwich plate, provided the port you connect to sees constant pressure.
Jeff
