Universal antenna, please help!!
So i bought a universal antenna from AutoZone because the antenna i have now is just a flimsy little thing of rubber. so I've taken the plastic interior out to better expose the area ill be working in and what i see is a, i believe to be, drainage tube except it starts as one hose bet then splits off into two. the replacement antenna only has one drain attachment at the bottom of the motor :3d_frown:. also for the life of me i cant figure out how to get the existing antenna out. under the fender is got two prongs shaped like U's holding it to the metal and if u take the rubber off of the antenna there's a screw that u can turn and then it wont move anymore no matter how much force is applied :: angry ::. if anyone can tell me what to do for both of these problems i would greatly appreciate it.
