Two VSV's which one connects to where?
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
Hello,
There are two VSV connectors from the Ecu harness which are the same..how would i know which one goes to which. Both have the same connector and same color. It can also be switch...how would i determine which is for FPU and for the EGR
8,898
EGR is the one you can see under the manifold. You can compare the schematic lines yourself and see it.
You can not see the FPU valve. If you remove the alternator, you can see it easily. Or do you mean something else?
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
well just got a new engine installed and and the plug connects or goes in the vsv are the same..i dont know which goes where?same color and same fit
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
OK...there are two vsv ryt?FPU and EGR....there two connectors from harness...they are both the same in color and same fit to the vsv>.....my question is which goes where?
