Hello all just asking if you turbo gurus out there think this is a good deal or a bad idea, first up ive got a 89 7m that has a FFI,upgraded intercooler, 2.5 ali pipes, stock ct26 but with a high flow elbow otherwise stock
Machined head stock toyota gasket with arps
This has come up for auction in new zealands version of E-Bay what do you guys think? theres no specs expept of whats there
The turbos been run on a 7m powerd jet boat at 18psi
copyied from auction :
This turbocharger was build to suit Toyata 3lt.with Grand Nat Comp wheel and cover,Carbon seal back plate and watercooled B/housing.
Stage 3 Turbine and CT26 housing.
Bolted 270o thrust.
Internal waste gate
No shaft play at all, only been on motor for 1000klm
cost around $2,500 to build, it was built by Diesel Pumps Ltd CHCH
link to expired auction http://www.trademe.co.nz/Browse/Listing.aspx?id=89864829
The sale price is NZD $700 which is USD $483.459
Bolted 270o thrust.
Internal waste gate
