Turbo Timer Won't Work
MKIIITrbo89
West Chester PA
My turbo timer(Blitz Duel TT) was working fine. After I got the car back from my mechanic it did not work. I checked all of the connections where the ignition adapter is and the cables going to the turbo timer. Everything seems fine. I even tried the ground in a couple of places and still it won't turn on.
When I originally installed it I did not ground it and it got power but would just not keep the car running since it was not grounded. So some how it is not getting power. Anyone have any ideas??
Is there any way to test the cables or give it power some other way to make sure its not broken?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Need to check and make sure the E brake option is working and connected.
Also, unplug the unit, and then plug back in.
My HKS took a crap one day just out of the blue. Unplugged it and wala! Works great.
MKIIITrbo89
West Chester PA
Originally when I installed it I had nothing hooked up except just plugging the harness in and the unit worked fine. It just did not keep the car idling until I grounded the specific wire. So it should work without any accories hooked up at least get power. I unplugged everything and plugged in back in. Still no luck. I will fiddle with it some more tomorrow. While the car was running I unhooked the adapter for the harness and the car shut off. So that works but maybe the wires which go from the adapter to the TT have a loose connection? I'm really not sure what to think.
