Does anyone know if the return line on the turbo flows freely or should there be some resistance when I blow thru it?
jdub;1299286 said:It should flow freely...no resistance.
The obstruction must be in the block... the lins was clear. Turbo is a Boss Jr. from Suprasport.jdub;1299296 said:Replace the line or take it off and throughly clean it...the feed line too while you're at it.
What kind of turbo?
jdub;1299306 said:Stock return location? That would be hard to do...it's a straight shot to the pan from the block turbo return.
jdub;1299324 said:Negative slope all the way from the turbo to the block? Kinked line?
