Trying to get tach to work - Wiring issue
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
Ok, so I've tried almost every combination I can think of for getting my tach to work with no luck.
1. NA Gauge Cluster -> NA Tach -> turbo tach pcb
2. Na Gauge Cluster -> Turbo Tach
3. Turbo Gauge Cluster -> NA Tach -> Turbo tach pcb
4. Turbo Gauge Cluster -> Turbo Tach
Nothing works. Now, I believe it is a wiring issue somewhere, I don't believe the tach signal is reaching the gauge cluster. (A give away to that is I tried an aftermarket tach and i I couldn't get it to work off the little ign signal at the diag block)..
How and what do I test to check to make sure I have a signal going to my tach?
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Now when you say, NA cluster and NA tach with turbo pcb....does that mean that you swapped boards or soldered in the new resistors? I dont know if it makes a difference but on my NA cluster and NA tach, I just soldered the different resistors onto my pcb and my tach works awesome.
