Trunk leaks when opened
1987mk3turbo
12
Steinbach
every time i open my trunk water spills into the trunk is this a common problem or do i have to fix something? nothing leaks in when it is closed
lagged
1991 1JZ
new rochelle
water is probably collecting in the trim. get some clear silicon sealant, remove the rear hatch window moldings, apply sealant, reinstall moldings and your leak should be gone.
JustinGotA1j
532
Chilliwack
I have this same problem. I'll have to try this out. Thanks!
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
If water pours out from the plastic cover on the underside of your hatch its usually the trim at the bottom of the windshield or the spoiler seals. In my case it was both so I had to fix the trim and get news seals for the wing.
Leaky taillight gaskets will leak water into your car and usually settle in the spare tire well. You're taillights may also fog up.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
you mean that black plastic trim at the bottom of the back glass? mine's been gone forever and im always wondering where the hell the water is coming from :D
BigTree
Targa JZA70 FTW
Jan 6, 2007
175
Canada, BC
OMG you guys are awesome!! Ive been trying to figure out where it was coming in and was going to get new gaskets for the wing even though it looked dry there out of desperation.
Awesomeness.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Which trim? The plastic on the underside of the hatch just pops off. Once you pop that off you can get to the nuts that hold the trim on the bottom of the rear window. You have to take the nuts off and them pop the trim off. You can also get to the wing fasteners that way too.
Clip
Oct 16, 2005
2,738
9
Virginia
Island_Yota;1231783 said:
How do I remove the trim? mine leaks the same way dont want to break the trim pieces.
unless you're talking about the black trim. that's some sort of thin plastic weather stripping that is glued (maybe?) to the top and bottom of the metal around the hatch glass. mine is broken and cracked, and 90% missing so i was going to clean up the edges with a utility knife and then run a bead of black silicone between the two surfaces. if i had time i might tape up the car and spray the trim black again.
Island_Yota
264
Vancouver Island
thats what I need to do, how do I remove the trim? I looked at a diagram on the TSRM, doesn't really show it.
water collects in the plastic cover on the inside of the hatch, the plastic cover was missing a few clips when I took it off and the 3rd brake light cover was off when I bought the car so im guessing someone has attempted to fix the problem already.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
