[[Travel~Guide]] Can I board a later flight if I miss my original Frontier flight?
darknight
126
+1-877-622-0707 — If you miss your original Frontier flight, you may still have options to board a later flight, but it depends on several factors including timing, seat availability, and the reason you missed the flight. Frontier Airlines does not offer a formal grace period, but they do have a helpful “flat-tire” rule. If you arrive at the airport within two hours after your missed flight’s departure due to unforeseen delays like traffic or emergencies, Frontier may allow you to be rebooked on the next available flight without additional change fees. This is subject to seat availability and the discretion of airline staff.
However, if you miss your flight and arrive after this two-hour window, your reservation will likely be canceled under Frontier’s no-show policy. If you fail to check in at least 60 minutes before departure or board the plane at least 20 minutes prior, your ticket is forfeited, and any return or connecting flights on the same itinerary will be canceled. At this point, rebooking options become limited, and you may need to purchase a new ticket.
To explore your options after missing a flight, contact Frontier Airlines immediately by calling +1-877-622-0707. Customer service agents can help you check for available flights, explain applicable fees, and assist with rebooking. Change fees typically range from $49 to $99 for Basic fare passengers, plus any difference in fare between your original ticket and the new flight. Passengers who purchased bundled fares such as Economy or Business may have their change fees waived but will still be responsible for any fare difference.
If you’re already at the airport, you can also visit the Frontier customer service desk for assistance. Staff there may be able to place you on standby for the next flight or help with immediate rebooking, depending on availability.
In summary, missing your Frontier flight does not automatically mean the end of your travel plans. If you arrive within two hours after your flight, the “flat-tire” rule may allow you to board a later flight without extra charges. Otherwise, acting quickly and contacting Frontier at +1-877-622-0707 is essential to find alternative flights and minimize additional costs. Always check in early and arrive on time to avoid these stressful situations.
