Does anyone know if the speedo drive gear on the main shaft and driven gear in the speedo cable adapter are interchangable between the R145 and the W58 trans?
I guess that my main concern is whether or not the drive gear on the tranny main shaft is interchangable between the two trannies. I know that the adapter housings are the same for the driven gear so those gears are or should be interchangable. So again, the question is whether or not the drive gears on the main shafts are
