TPS Question.......
supraguy31
626
Pembroke, NC
How can you tell if you have a Dead Spot in yout TPS?
Ive set the TPS Using the 88 TSRM so Its correctly set. If I very slowly give it gas at Idle and it Hits a Certain RPM, The engine will start to rev up and down, up and down. I was driving it today and I hit that shot and the car started bucking back and forth.
Its like that rev up - cut fuel - rev up - cut fuel until I get out of that RPM spot.
I want to fix this so any help would be greatly appreciated.
Robert
dumbo
1,911
Albera, Too Far North
Robert
TPS volatge has nothing to do with RPM, a dead spot would cause the car to basically die, tps would read 0volts, an open
dumbo
1,911
Nick M;1172697 said:
With a scope. It will show voltage over time, if you don't know what one is.
http://cgi.ebay.com/New-FLUKE-97-SC...yZ104247QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Your symptom is strange. If you have a dead spot, you will go lean, but not by much.
you dont need one of those, a regular volt meter will do it.
http://img.photobucket.com/albums/v293/heedah007/maftpropre89diagram.jpg
connect to VTA and ground and have a friend VERY slowly press the gas pedal, if at any points it gets lower volatge reading, thats a prob. approx .5v is idle, and( tsrm states WOT) my wot is 3.48v
but i bet it aint your tps, you got any codes?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
He didn't say what rpm it cuts out at but it could be the IDL contact isn't opening or is intermittently shorting. That results in rpm cut, something that sounds similar to his symptom. He should:
1) Jumper T and E1.
2) Key on, engine off.
3) Slowly press gas pedal to the floor.
4) Check for a code 51 at every pedal position except idle.
VTA can be checked as you described. That said the engine will not die with an open in either of those circuits. In fact it'll run pretty well with the TPS unplugged, something else he may want to try.
dumbo
1,911
1) Jumper T and E1.
i dont understand how you check code 51 not at idle?? actually its not very clear at all, sorry. but i'm not wanting to jack his topic. i think you've gave him a good start.
supraguy31
626
Pembroke, NC
1) Jumper T and E1.
Ok, did said check and without pressing the Pedal, I dont have a Code 51, As soon as I give the pedal a little press, Code 51 comes up and I have that code all the way down to WOT. only thing that I noticed is when my Pedal is 100% down, Im reading 3.08v on my MAFT Pros TPS reading.
dumbo
1,911
yah that is below spec.. i would get a friend to check your reading, and manually open the tb under the hood. and if that isn't it, maybe jetjock will share some knowledge.
since you got it hooked up to your maft..you can just use that as your voltmeter...thats how i've checked mine.
