Okay todays project was to change the o ring in cam sensor for 7mgte I did exactally what the book said when reinstalling it put no1 cyl on tdc and align the marks on the cam sensor with drilled hole in the gear got her button up when to check timing and also putting wire between te and e1 and timing is showing 20 degrees so i reset the cam sensor again now its at 0 degress and the most i can ajust is up to 7 degrees any help would be great.:1zhelp:
