Timing Belt...Radiator Removal?
Apostle
88
Philly
I'm doing my timing belt, and I was wondering if anyone here has been successful doing the job with the radiator still in place. I checked the TSRM and it says the radiator has to be removed, just wondering if theres a way around it. There seems to be enough room to work with but I just want opinions.
Thanks
8,900
Not needed with the right tools. I am guessing you don't have the right tools.
And when it comes time, don't put a breaker bar on the crank bolt, and operate the starter motor.
jgcable
180
Milford, CT
It takes 20 minutes to remove the radiator. You will end up putting a hole in it trying to get everything off the front of the motor if you don't take it off.
The crank bolt is insanely tight. Something like 195ft lbs. I used a 3' breaker bar while jamming the flywheel with a really large screwdriver.
It will also be hard to get the fan off of the waterpump with the radiator in place.
Captain
80
NM
CTsupra;1150575 said:
Save yourself the bloody knuckles, cursing, damning, stress, broken parts.. see a pattern here? Take the rad and fan out.
I've done it with the radiator in and thats exactally what happened. It was a thick rad too...
pb92supraturbo
FTG & the IRL!
Aug 20, 2005
172
Garage, under Supra
If you do remove it, be careful not to accidentally hit what’s in front of it - the condenser. I almost hit mine while pulling off the crank pulley when it suddenly released. Next time, I'll leave the crank pulley bolt threaded it a few turns to catch it.
5
Yeah, and 15 minutes of that is draining the coolant...
It's very easy to do...
