Thermostat switch
xms
269
tx
Does anybody know if there thermoswitch on the thermostat housing on the 7mgte motor
jdub
Feb 10, 2006
10,730
Valley of the Sun
The condensor and aux fans use switches on the thermo housing.
There's the cold start injector time switch too.
It would help if we knew what you are trying to do.
xms
269
tx
I am making a switch to automatically turn my coolant fans on, I bascially made a relay, but it work only when the car turns on and it stays on, so i want to make turn a certain temperture like 185 degrees and turn off at 170
jdub
Feb 10, 2006
10,730
Valley of the Sun
The two stock fan switches operate well above those temps. One functions on @ 234 degs & off @ 225 degs. The other comes on at 212 degs & off at 203 degs. You will have to find an aftermarket switch to do what you want.
xms
269
tx
Jdub do u know which sensor is the 212 one? and does it work of ground?
